Irregular mesh
Old   February 1, 2013, 07:37
Default Irregular mesh
stonescar is on a distinguished road
I am very new to CFD and I am trying to just make a domain and generate waves in this domain. So when I try to make a mesh, it looks kind of weird.
Why does spots with higher density of cells occur at random places, as seen in attached picture.
I guess there's a simple setting or something I haven't checked.
Sorry for a very newbie question.
stonescar is offline   Reply With Quote
Old   February 7, 2013, 01:55
sam
Sam0508 is on a distinguished road
Originally Posted by stonescar View Post
Can you check the surface growth rate? ref below
Regards,
Sam0508
Regards,
Sam
Sam0508 is offline   Reply With Quote
Old   February 12, 2013, 05:57
KHB
lava12005 is on a distinguished road
Hmm before going to the volume mesh, can you show us the surface mesh /intial surface of the domain? (make sure the mesh if on to be seen)
I suspect there is something not righ even with the surface mesh / initial surface
lava12005 is offline   Reply With Quote
Old   February 27, 2013, 03:02
Melih Meriç
mmntmflx is on a distinguished road
You can try to check these values,
* Surface curvature (reduce the default value - this put more less points around the circle)
* Surface size (increase the cell size - increase the minimum triangle size)
and can you show geometry screen?
i think geometry have some circular feature edges on the extensive areas like a point,
and i think some close proximity detail in extensive meshed line..
mmntmflx is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Meshing & Mesh Conversion 14 December 12, 2018 08:07
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 13:40
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 04:49
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
