-   STAR-CCM+ (http://www.cfd-online.com/Forums/star-ccm/)
-   -   Problems Modelling Combustion in a Reactant Filled Region (http://www.cfd-online.com/Forums/star-ccm/113818-problems-modelling-combustion-reactant-filled-region.html)
BarryC February 27, 2013 07:39
I am trying to model combustion inside a region that is filled with reactants. The idea is that this region is filled with reactants before combustion occurs, as opposed to having a continous flow from the inlets to the outlets. To be specific, I hope to model the flame front as it moves through the region.
The only way I can see of acchieving this is to use a volume of fluid physics model, where air inside the region is displaced by the reactants before combustion, however, the volume of fluid physics model seems to be incompatible with the combustion physics models.
Does anyone have any suggestions on how to do this? Can this be done in the current version of STAR-CCM?
Thanks,
Barry
abdullahkarimi May 21, 2013 22:26
Originally Posted by BarryC (Post 410421)
Thanks,
Barry
I think you mean that you want to mode premixed combustion in a constant volume. You can do it simply by using the initial values of reactants and then start the simulation. You can also use ignitors if you need.
