March 6, 2013, 12:29 |
Field function for translation
Arun Krishnan.L.H
Dear all,
I have created a filed function for oscillation of a cylinder on free surface and then was trying to provide reference of the field function in translation. I am getting an error during this operation. Cannot evaluate expression $$WallVelocity on Simulation>MotionManager>TranslatingMotion("Transl ation")>VectorPhysicalQuantity>InlineFieldFunction ("InlineFieldFunction") Command: SetProperties My field function name is WallVelocity I have defined it as [(($Time<0.05) ? (1*$$Position(“wall”) [1]) : (0.1*sin(360./6.2831853*$Time)*$$Position(“wall”) [1])), 0, 0] a simple SHM with amplitude of 0.1 and frequency of 1 rad/s. This does not show any syntax error. Then i refer the field function using $$WallVelocity in my translation motion and i get the error specified above? Can anyone guide me where things are going wrong? Thanks Regards Arun |
March 6, 2013, 12:49 |
Andrew L. Bloxom
Did you set the type and function name in the properties window?
Did you use a Tools>Motions, to define a Translation Motion with you field function at the Translation Velocity? |
March 6, 2013, 14:21 |
#3 | |
Arun Krishnan.L.H
I did assign type as velocity and function name as WallVelocity and Translation velocity was assigned $$WallVelocity. Thanks Regards Arun |
March 6, 2013, 14:25 |
Arun Krishnan.L.H
Also this is a problem of free surface with VOF definition. To specify calm water condition with no velocity, i have defined VOF waves and given 0.0 amplitude.
Is it possible to have a wall condition and symmetry planes all around and still define VOF waves?I am getting an error. Can you please tell me how to specify a calm water condition with the motion of this cylinder on free surface? If you could just guide. Regards Arun |
March 6, 2013, 14:42 |
Andrew L. Bloxom
You should be able to define a flat wave, use the hydrostatic and volume fraction definitions for your initial condition and then oscillate it. You may want to make the bottom a zero velocity inlet and the top a pressure outlet.
I'm not sure about your wall velocity function. You might want to try and implement the motion through a grid velocity applied to the top and bottom with the morpher. |
March 6, 2013, 17:44 |
Arun Krishnan.L.H
Thanks a lot.
Will try your suggestions. Regards Arun |
problems after decomposing for running | alessio.nz | OpenFOAM | 7 | March 5, 2021 04:49 |
Force Report help~ or maybe Custom Field Function | sailor | FLUENT | 0 | April 13, 2011 03:45 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 06:59 |
