Help with meshing thin regions for fluid flow
Old   March 6, 2013, 13:34
Default Help with meshing thin regions for fluid flow
Barry Sunderland
BarryS is on a distinguished road
does anyone have any recomendations for meshing very thin regions to model fluid flow? I have reasonably simple geometry where the inlet pipe is 2mm in diameter goes into a larger 5mm dia cylinder and then flows across up and across a very narrow gap, .2mm, between two parallel plates.
Using Star CCM+, is there any way of generating enough cells across the gap to capture the flow profile without using millions of polyhedral cells?
The thin mesher would seem to be ideal but Im not sure if it is suitable for fluid flow and the mesh become quite skewed at the junction between polyhedral and thin layer cells.
thanks for your help,
Barry
BarryS is offline   Reply With Quote
Old   May 22, 2013, 04:54
Sam
sameben is on a distinguished road
You should try some simple hex meshing for this problem.
sameben is offline   Reply With Quote
Thin Channel Meshing in DM chires ANSYS Meshing & Geometry 1 March 29, 2011 18:51
thin extrusion meshing guillaume Main CFD Forum 0 October 27, 2008 18:36
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
Meshing thin surfaces Louwrens CFX 8 August 18, 2003 17:49
meshing for surface ship flow boris FLUENT 0 April 24, 2002 20:27
