-   STAR-CCM+ (http://www.cfd-online.com/Forums/star-ccm/)
-   -   Mimic (copy) of a Boundary (http://www.cfd-online.com/Forums/star-ccm/114442-mimic-copy-boundary.html)
mk_mard March 11, 2013 08:57
Hello everyone,
In my simulation domain I have two different 'continua'-s - and there are some inlets and outlets on each continua.
I want to mimic (copy) the 'outlet' boundary conditions from one domain to the 'inlet' of other domain - obviously on the outlet I know the flow rate, temperature and the pressure. How can I replicate these parameters on the inlet of the other domain?
For example, on one of the outlets I have air at 1kg/h, 400C and 100mbar. I would like to have the same values as 'inlet' parameters somewhere else in the computational domain?
any help?
Many thanks,
siara817 March 11, 2013 16:27
Can you put a picture from your geometry?
mk_mard March 12, 2013 10:00
1 Attachment(s)
Have a look at the attached picture - this is simplified version of what I have.
Basically, the parameters in 'Inlet-2' should be the same as 'Outlet-1' - that is the pressure, flow rate and temperature.
In other words, the gas should continue in the second pipe with the same conditions - the physics continua is not the same in both pipes.
siara817 March 13, 2013 04:31
If you select velocity inlet for the second inlet, then you can give the values to the temperature and flow rate.
mk_mard March 13, 2013 04:40
Yes, that is correct but how can I apply the exact pressure? to have a continues pressure drop?
abdul099 March 21, 2013 18:21
Try it with a table, auto extract and interpolate to a field function.
