Macro execution
Hello together,
at this time I got headache from my problem so I thought it´s time to ask you. I´ve recorded a Macro in Java (a very simple one to create a geometry, mesh it and afterwards run a simulation). I also used Netbeans to create a GUI with a "Simulation" Button. So as you know i´ve got two classes (both in the same package). When the button is pressed the simulation shall start. Class ONE: Macro code recorded from java with "execute0" for the methode to create geometry, mesh and run simulation. Class TWO: GUI with "Simulation" Button. I used in Class TWO: ONE start = new ONE(); ... ... ... SimulationButtonActionPerformed(...){ start.execute0(); } If I run the macro the GUI is shown correctly. BUT I always get a Nullpointerexception at CadModel cadModel_0 = simulation.get(SolidModelManager.class).createSoli dModel(); Can you please help me with this problem. Thanks a lot in advance Best regards, Bastian |
Have you tried running your macro file with class ONE? Click the button "Play Macro" and select the file ONE.java. Does it work properly? Could you show all the jave-code of your class ONE declaration?
