[Sponsors] | |||||
Torbjørn Stensrud
Rep Power: 2 ![]() |
I'm very new to CFD and Star-CCM+ and I'm not sure how to improve my residuals. The image below shows my simulation after 2000 iterations.
![]() I would very much like to improve on my energy and continuity. What causes the residuals to barely drop below 0.01? I have tried to lower the under-relaxation factors and create lower base size on my mesh, but no help so far. |
Kyle McVay
The convergence criteria differs between simulations, although .01 is rather large. I would run reports to check mass flow at inlet and outlet and compare, also do you have reversed flow at the outlet? Additionally maybe your physics model or volume meshing model isn't optimal for the simulations that you're doing.
Torbjørn Stensrud
There are no massflow inlet or outlets. The velocities are purely because of natural convection. I'm using a polyhedral meshing model with a 2-layer prism layer.
Kyle McVay
Your meshing model should be fine. Maybe check if the flow is turbulent or laminar. If you run a turbulent model as a laminar model then it won't converge; I'm not sure if laminar flow under turbulent model would converge or not although I feel like it would.
Kyle McVay
Also if its turbulent try running implicit unsteady instead of steady.
Describe the mesh, please. From what i see - i would suppose this as a result of coarse mesh.
Torbjørn Stensrud
It worked out fine when I changed from turbulent to laminar model, so everything is all right now. Thanks.
siamak rahimi ardkapan
Rep Power: 5 ![]() |
Hi
No one can say that the results of the simulation are wrong because of high residuals. As Kylea&M told, you need to check mass conservation or energy conservation. If you are simulating air movements in the room caused by a heat source, the pattern is substantially turbulent and simulating by laminar give wrong results.
Good luck Siamak |
#9 |
Ryne Whitehill
Rep Power: 7 ![]() |
With natural convection problems, I believe it is best to switch to a bouyancy driven "two-layer type" when using the k-epsilon turb. model.
This is under Continua->Physics->Models->Realizable K-Epsilon Two Layer disregard if you are using k-omega. |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| motorBike Residuals for SST k-omega... and mine | JR22 | OpenFOAM Running, Solving & CFD | 1 | April 17, 2013 14:43 |
| Tutorial of how to plot residuals ! | wolle1982 | OpenFOAM Running, Solving & CFD | 66 | April 11, 2013 07:08 |
| what to monitor besides residuals? | franzdrs | FLUENT | 5 | March 21, 2013 04:59 |
| judging convergence through residuals | MachZero | Main CFD Forum | 7 | December 25, 2012 12:18 |
| Convergence - scaled vs unscaled residuals | HS | FLUENT | 1 | November 7, 2005 05:45 |
