Query regarding Modelling Thermal mass decomposition in star CCm+
Old   April 30, 2013, 02:43
Question Query regarding Modelling Thermal mass decomposition in star CCm+
Himanshu Sharma
himanshu28 is on a distinguished road
i am working on the project and intending to use Star-CCm+
for the CFD simulation the brief description of the problem statement is provided below.
The title "Parametric and CFD Simulation of Condensed phase fire extinguisher". The basic idea behind this extinguisher is it generated the extinguishing gas in the form of aerosol.
The Mechanism for generation of aerosol is as follows :
Stage 1.
The solid propellent inside the chamber is combusted inside the chamber with some igniter this produces the hot gas mixture.
Stage 2.
Then the Hot gases interacts with Pellets(these are the chemical compounds which get decomposed when a hot gas is passed over it). This decomposition lead to the addition of mass in chamber.Due to this decomposition of the pellets the temperature of the Hot gas reduces since the energy of the Hot gas is been absorbed for the decomposition.
Stage 3.These reduction in temperature of the hot gas lead to condensation of some of the hot gas leading to the generation of the aerosol
To model this complete phenomenon as a test the following simplification was made
1. Stage 1 is not modeled which is the combustion modelling.An outcome of the combustion products are put as an initial input to the system.
The main difficulty is arising the modelling of the second stage.I have try ed and studied various heat transfer simulation models but unable to find the solution.It will be helpful if you suggest is it possible to model this Thermal Mass decomposition of the pellets due to Hot gas interaction with Star-CCM+
Regards
Himanshu Sharma
himanshu28 is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
mass flow rate in STAR CD V3.26 Paolo Siemens 3 January 15, 2009 16:36
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
