Morphing
Old   May 1, 2013, 08:14
Question Morphing
TSC
Tim
TSC is on a distinguished road
Hello all,
I am trying to simulate a boat (2 DOVs) with flat water conditions. Therefore I use the DFBI Rot+Trans Model in combination with a DFBI Morpher.
First I generate two blocks, one around the ship, the other reflects the computational domain. An interface connects both blocks.
Now the block around the ship uses the DFBI Rot+Trans model, as the computaional domain gets the DFBI Morpher. After the release time ends and ramping begins I get the error:
"Warning: 5 cells in region Subtract have zero or negative volume. This may be due to an invalid imported mesh or to errors initializing an interface. Repair the mesh before proceeding."
This means the inner block (ship) starts to move while the outer block (domain) is fixed and there are intersection resulting zero volume cells (pic: http://s7.directupload.net/images/130501/lnhfjrht.png).
Why both blocks aren't connected? I initialized the interface before running and check the mesh for any errors. Maybe the resulting moments are too big for the DFBI Morpher?
TSC is offline   Reply With Quote
Old   May 21, 2013, 22:00
Abdullah Karimi
abdullahkarimi is on a distinguished road
Make sure that you choose 'floating' method for Morpher for the interface boundary which is not moving.
I was getting this problem and after using 'floating', the problem got resolved.
abdullahkarimi is offline   Reply With Quote
Old   June 12, 2016, 04:08
Question How about the interface boundary which is moving?
Yi
lyly0309 is on a distinguished road
You said using "floating" for the static interface boundary, but in fact when these two DFBI modules combined, the interface boundary should move as the DFBI Rot and Trans moves. So do you know what kind of morphing boundary should be set for these moving interface boundaries ? Thank you very much!
lyly0309 is offline   Reply With Quote
Old   June 21, 2016, 17:23
Arrow
Falak Sher
falak is on a distinguished road
Dear I have a cylinder when i apply DFBI translation and rot on this my whole domain starts moving. Do I need to apply morphing ?
falak is offline   Reply With Quote
Old   June 22, 2016, 06:20
Gajendra Gulgulia
ggulgulia is on a distinguished road
Hello TSC,
The issue might be probably due to a local cell set becoming invalid in addition to what you mentioned. This issue is majorly due to cell quality becoming progressively poor as the morpher proceeds to deform the domain on interest. This is the same reason morpher is not recommended for large displacements.
Secondly, you might want to make sure that the displacement in one time step should not be greater than the smallest cell size anywhere in the domain. Ofcourse this stems from the courant number conformality requirement in CFD.
If your displacement is large, I suggest go for overset mesh. Or else you can have a macro run the simulation which will remesh the computational domain once the cell quality due to morpher displacement falls below desired limit.
ggulgulia is offline   Reply With Quote
Old   June 28, 2016, 09:56
Yi
Originally Posted by ggulgulia View Post
Hello TSC,
Dear ggulgulia :
You said that we can remesh the computational domain. But when the domain are remeshed , the domain also returns to the original state. That is to say displacement returns to zero again. Do you mean that there is a another method to remesh domain while keep the morpher displacement unchanged? And How to remesh the domain to improve the mesh quality? Thank You !
Old   March 9, 2017, 04:30
uchiha madara
Frikha is on a distinguished road
Hi , ihave the same problem does any one has a solutioN??
"1747 cells in region Domaine fluide supérieur have zero or negative volume. This may be due to an invalid imported mesh or to errors initializing an interface. Repair the mesh before proceeding."
Frikha is offline   Reply With Quote
Old   March 9, 2017, 12:48
me3840 is on a distinguished road
The solution to this issue is very case-dependent. You will not get a "click this button and it works" answer.
This thread is already 4 years old. Considering how different the issues are between your case and the original for this thread, please make a new one and describe your problem in detail.
me3840 is offline   Reply With Quote
Old   March 9, 2017, 13:25
uchiha madara
for sure , i have search , my case was a mving piston inside a chamber , which is in compresion and expansion state ,and i think before posting any issues here , i need to learn often about mesh motion and morphing .
Old   October 16, 2023, 12:35
Islam Abdelghafar
Islam Abdelghafar is on a distinguished road
When you use 'Floating' it will not be rigid anymore and the boundary wall will move or morph and for sure you need it to be fixed not moving or morphing.
I have tried to set the 'Six DOF Morpher Specification' of the fixed boundary wall to 'Constraint', then choose 'Initial Boundary' for the 'Morpher Constraint Specification, however, remeshing will be needed as some point.
Islam Abdelghafar is offline   Reply With Quote
dfbi morpher, morphing, morphing motion
[Other] Morphing wing cfd analysis in transition rekfuh ANSYS Meshing & Geometry 0 June 6, 2012 09:22
RBF for Morphing andrea.pasquali OpenFOAM 2 December 5, 2011 05:10
Mesh Morphing in CFX ??? vmlxb6 CFX 10 March 9, 2011 14:59
mesh morphing CFDude Siemens 1 February 10, 2009 08:19
FLOTRAN: what is morphing? yusun Main CFD Forum 0 December 31, 2004 04:27
