-   STAR-CCM+ (
-   -   heaving of a cylinder (
arun7328 May 6, 2013 11:03
4 Attachment(s)
Hi All,
I have posted this question before but got no replies. I request you to please guide me if you know anything about this problem.
I am trying to evaluate the hydrodynamic force on a cylinder which is heaving with an amplitude of 0.03 m( vertical which is y axis) and frequencies from 1-6 rad/s. The motion is sinusoidal with a velocity of 0.03 cos(wt). I am using morphing for this problem. The results I have attached is for 6.64 rad/sec. I have simulated the problem of swaying and successfully compared the results with experiments.
For heaving I have attached 3 force plots from STAR CCM+.
1. vertical force on the body with pressure only selected.
2. Surface integral of total force.
3. Surface integral of static force.
As per the results the static and total force seems to be the same. The vertical force is lower than what is obtained from 2 and 3. As per the manual Vertical force(pressure), is the surface force that acts on the wall. In that case i assume it must be giving me the total force with the static component?
Why is it then lesser than static and total? Why is the total and static forces equal to each other? How do I get the dynamic component?
The radius of the cylinder is 0.5 m.
Any suggestions would help me. I have gone through all the threads and could not find anything relevant.
Attachment 21497
Attachment 21498
Attachment 21499
Attachment 21500
Please respond.
arun7328 May 9, 2013 10:47
Can anyone give some suggestion pls?
