May 15, 2013, 10:04 |
User field function "if" condition
Rep Power: 13 |
I'm having one interface between two rooms at different temperature. Natural convection is accuring between the rooms. Hot air is entering at the top of the interface and cold air is leaving at the bottom. My question is how can I define an unser field function (and surface integral) to measure the flow entering the interface. I tried the following but didn't work : ($$Velocity[0] >= 0) ? $$Velocity[0] : 0 Can you help me, I'm not confortable with field function. Thanks, Djack |
May 15, 2013, 17:20 |
Chaotic Water
Rep Power: 17 |
Hi
I've tried the problem you described - and it works fine exactly with the field function you wrote and Surface Integral over the Interface between rooms. Describe the problem, please |
May 16, 2013, 03:35 |
Rep Power: 13 |
You're absolutly right !
Thanks |
problems after decomposing for running | alessio.nz | OpenFOAM | 7 | March 5, 2021 04:49 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 06:59 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
