Shaft rotating in fluid CHT
I am looking at simulating a shaft rotating inside a cavity of air with the aim of monitoring the torque on the shaft due to viscosity. Added to this I would like to have the actual shaft solid part in the simulation so that I can see how the viscous heating affects the shaft temperature. I have already ran the simulation with a "fluid only" domain whereby I specify the tangential velocity method on the surface that coincides with the rotating shaft surface. I have got good results using this method. I now want to include the solid shaft in the simulation. I have tried several methods but I always seem to get very low torque on the shaft compared to the tangential velocity method, they should be exactly the same. I have the full fluid and solid regions and have defined an in-place contact interface where the shaft is in contact with the fluid. If I specify a tangential velocity for the contact interface between the fluid and solid I get zero torque on the interface. I have also tried to set the solid shaft region as a moving reference frame but get the same results. It sounds like it should be a fairly simple method because essentially I have a shaft rotating in a fluid that I want to simulate. Any help would be greatly appreciated. Thanks |
