reason for divergence
Old   May 8, 2013, 12:13
Default reason for divergence
Rohit Ray
rayzcorp is on a distinguished road
I am running a simulation for a sphere with seam in air flow. when i rotated the seam and ran the simulation again, the solution is not converging. I did keep all the conditions same as the earlier case.
Can suggest me what to check if your Tke and Tdr aren't converging?
rayzcorp is offline   Reply With Quote
Old   May 14, 2013, 12:57
kw
Kasey is on a distinguished road
Try selecting "Cell Quality Remediation" as an optional physics model.
It could also mean that you need to decrease your mesh size.
Kasey is offline   Reply With Quote
Old   May 29, 2013, 13:43
Kiran
Fluidengineer is on a distinguished road
Hi
Along with addition of cell quality remediation reduce the under relaxition parameter.
Still if it does not work then change the boundary conditions to lower values.
-kiran
Fluidengineer is offline   Reply With Quote
Reason for oscillating residuals fayaazhussain Main CFD Forum 3 August 21, 2014 10:31
[ICEM] What is the reason for this negative determinant? kiddmax ANSYS Meshing & Geometry 6 April 18, 2013 10:59
Reason for asymmetry in symmetric geometries doubtsincfd Main CFD Forum 1 June 10, 2010 08:13
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
Reason of divergence ? Brayton Main CFD Forum 3 December 2, 2000 22:34
