Home > Forums > STAR-CCM+
Airfoil moving inside a fluid - Results discussion
Old   July 4, 2013, 09:13
Default Airfoil moving inside a fluid - Results discussion
David
GM_XIII is on a distinguished road
Hi all:
I am trying to simulate an airfoild moving inside a fluid in Star CCM. The airfoil must move as a chirp function that i have defined. I ran it smoothly without problems using the following Models:
Segregated Fluid Temperature, Gravity, Two-Layer All y+ Wall Treatment, Realizable K-Epsilon Two-Layer, Constant Density, Rigid Body Motion and Three Dimensional.
I set a enough number of inner iterations to keep the residuals low. The problem is when i analyse the results they dont seem reasonable. I suspect the problem is caused by calculating the Downforce refered to the Laboratory Coordinate System instead of one linked to the airfoil, as the ''strage' fluctioations occur when the acelerattion change its sign.
I upload you some images and an excell document with all the data directly from star-ccm.
Very thanks you
pd: https://www.dropbox.com/s/juffyv05vouozvv/chirp.xlsx here is the excel data
GM_XIII is offline   Reply With Quote
Old   July 4, 2013, 18:19
David Hickerson
dahicke is on a distinguished road
Send a message via AIM to dahicke
Hi David, Have you looked at a velocity vector plot on the symmetry line to see, if there is some identifiable cause to the fluctuation? If not, try plotting pressure as color with velocity vectors on the background. Is the flow separating at that reversal? Have you refined the mesh to determine that it is not influencing the flow? Good Luck, Dave
dahicke is offline   Reply With Quote
Old   July 5, 2013, 08:09
David
Thank you for your answer Dave. I will record that representation as soon as i can but correct me i'm wrong, if ihad reversal i shouldn'n have had a lower value of Downforce. By the way,i dint post it but in the drag this fluctuation is not that notorial.
Old   July 5, 2013, 17:02
David Hickerson
If I understand your setup right, you have a symmetric airfoil at some angle of attack which is vibrating at your specified chirp function driving z position. You are measuring down force (-lift) and drag over time as the system vibrates.
I am thinking that at the change in direction depending on the rate of acceleration, you may see a momentary flow separation due to the change in momentum of the air around the foil, which is unable make the abrupt change in direction. If this is happening, then down force would fluctuate because of loss of lift by the air foil.
Dave
Old   July 18, 2013, 13:40
Default Flapping flat plate-pointDisplacement quries
psk
david
psk is an unknown quantity at this point
Good Day Folks,
I am trying to do flapping flat plate like cantilever beam simply up & down with amplitude is -12 to +12 ( similar to this you tube video: https://www.youtube.com/watch?v=s_gtukpyHXk ) and also wing beat frequency =10 Hz.
I am go through wing motion tutorial in pimpleDyMFoam in OF 1.7. I don't know how to set pointDisplacement for my case.I am looking only translation not rotation so, i can delete fixed axis ,( ie in red color) i hope its correct. kindly secure and guide me, how i can proceed?
_______________________________________________
dimensions [0 1 0 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
movingwing
type sixDoFRigidBodyDisplacement;
mass 22.9;
centreOfMass (0.4974612746 -0.01671895744 0.125);
momentOfInertia (1.958864357 3.920839234 2.057121362);
orientation
0.9953705935 0.09611129781 0
-0.09611129781 0.9953705935 0
0 0 1
velocity (0 0 0);
acceleration (0 0 0);
angularMomentum (0 0 -0.5);
torque (0 0 0);
rhoName rhoInf;
rhoInf 1;
g (0 -9.81 0);
report on;
constraints
maxIterations 500;
fixedLine1
sixDoFRigidBodyMotionConstraint fixedLine;
tolerance 1e-9;
relaxationFactor 0.7;
fixedLineCoeffs
refPoint (0.25 0.007 0.125);
direction (0 1 0);
fixedAxis1
sixDoFRigidBodyMotionConstraint fixedAxis;
tolerance 1e-06;
fixedAxisCoeffs
axis ( 0 0 1 );
restraints
verticalSpring
sixDoFRigidBodyMotionRestraint linearSpring;
linearSpringCoeffs
anchor (0.25 0.007 0.125);
refAttachmentPt (0.25 0.007 0.125);
stiffness 4000;
damping 2;
restLength 0;
axialSpring
sixDoFRigidBodyMotionRestraint linearAxialAngularSpring;
linearAxialAngularSpringCoeffs
axis (0 0 1);
stiffness 700;
damping 0.5;
referenceOrientation $orientation;
value uniform (0 0 0);
inlet
type fixedValue;
outlet
type fixedValue;
symmetry-------> front
symmetryPlane;
symmetry-------> Top
symmetryPlane;
symmetry-------> Bottom
symmetryPlane;
wallone----------> opposite to front( ie Back)
type fixedValue;
type fixedValue;
Million thanks,
david
psk is offline   Reply With Quote
Old   July 18, 2013, 16:55
David
Hi David
It is great to see you are trying to run a similar case and i am also interested in running this kind of symulations on Openfoam. But in order to openfoam expert see it, you should publish a new post in the openfoam forum, when you do so please let me kniw by pm
About my case, i couldnt do the graphic that dahicke advised me as i have not full access to the cluster where i run my simulations but i will have the results soon.
Best regards
Old   July 18, 2013, 22:29
psk
david
Greetings GM_XIII,
(But in order to openfoam expert see it, you should publish a new post in the openfoam forum, when you do so please let me kniw by pm)------->I don't know what it means,If u don't mind please be specific?
If you have any idea about my problem( see above post) its look like cantilever beam to flap up & down, how I can set for amplitude angle-12 to +12, and let frequency is 10hz.
Million Thanks,
david
Thread Tools
Trackbacks are On
heat generation inside fluid omernuke FLUENT 3 May 5, 2010 11:27
how to model heat transfer inside a slow moving bed? bigfans FLUENT 1 October 9, 2009 00:12
Airfoil boundary condition Frank Main CFD Forum 1 April 21, 2008 18:36
Airfoil y+ Results Query asd Main CFD Forum 1 June 22, 2007 08:02
Negative propulsive efficiency of a moving airfoil zonexo Main CFD Forum 4 March 7, 2007 01:16
