Rotation of Impeller
Old   July 12, 2013, 05:18
Question Rotation of Impeller
Jay Rich
Richy is on a distinguished road
I am working on modelling a high speed impeller. I have done the Tutorial of the fan (both the reference frame and rigid body motion). I am having trouble running the unsteady simulation. I follow the steps of the tutorial (obviously using parameters appropriate to my model) but I keep getting a floating point error?
Any suggestions? I think it might be mesh related? Do i need a special mesh for the motion to work correctly?
Thanks
Richy is offline   Reply With Quote
Old   August 5, 2013, 19:26
malu
malfrienz is on a distinguished road
Hi has your problem been resolved? I have been getting the same error and i tried using very low residuals as mentioned in multiphase (my simulation has multiphase models as well). And also perhaps you could try first with first order and then once settled, change it to 2nd order.
Let me know how you solved this problem.
thanks.
malfrienz is offline   Reply With Quote
Old   August 5, 2013, 21:27
John Brown
frownless is on a distinguished road
When I did the second part of that tutorial where you move from steady to unsteady I found that it had frozen the solver. I needed to untick the box in the solver settings to get it to run properly.
Hope this helps!
frownless is offline   Reply With Quote
Old   August 12, 2013, 04:12
Jay Rich
Thanks for the help. I changed the inner iteration number and that seems to have solved the issue. The only concern I have now is the residual plot. During each time step, my residuals decrease sufficiently but as a new time step commences, they shoot back up. To me, this suggests that within each time step I am reaching some level of convergence. I know I need to look at other parameters to judge convergence, but I was just wondering about this?
Old   August 27, 2013, 07:43
Oliver Lauer
olauer is on a distinguished road
That's the way, RBM works. Everytime you move your mesh you increase the residuals in the interface regions.
For convergence checks you could have a look on pressure gain or torque or ...
olauer is offline   Reply With Quote
Old   August 27, 2013, 07:50
Jay Rich
Thanks. That makes sense actually
floating point error, impeller, mesh, rotating motion
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
CFX - Solidworks Flow, Impeller comparison aerospace_guy_ CFX 8 March 20, 2012 22:06
Problem rose from centrifugal impeller tim_shute FloEFD, FloWorks & FloTHERM 6 January 31, 2012 20:06
Axis of rotation for centrifugal compressor Mattia FLUENT 4 October 22, 2007 11:05
Rotation around the impeller Emre CFX 8 October 9, 2007 09:57
