July 12, 2013, 11:13 |
Flow diode boundary condition
Oliver Lauer
I am looking for something which is at least available in OpenFOAM and probably also in FLUENT.
I would like to have sort of a modified pressure boundary condition which suppresses inflow, that means if flow is going out of the domain => normal pressure boundary if flow is going into the domain => set boundary normal velocity to zero Is there any possibility to create such a boundary condition in CCM+? Could this somehow be realized by a user boundary condition? Any help appreciated. Oliver |
July 14, 2013, 03:28 |
siamak rahimi ardkapan
There is the option of pressure outlet boundary condition.
Good luck Siamak |
July 15, 2013, 04:20 |
Oliver Lauer
July 15, 2013, 08:51 |
There are some reasons for this inflow.
Sometimes because in the outlet the mesh is not enough fine. It is also a good idea to extrude the outlet, it helps removing the reversed flow. Because the software tries to reduce the pressure difference to zero, and this itself causes some reversed flows. If you extrude the outlet then you let enough length to reduce the pressure gradually. However, in reality reversed flow may happen .
Good luck Siamak |
July 15, 2013, 11:06 |
Oliver Lauer
I know why inflow could occur and I also know how to work around it.
Nevertheless I am looking for a "Flow diode" boundary condition like it is available in OpenFOAM with a possibility of setting boundary normal velocitiy component to zero if creating inflow. |
July 16, 2013, 11:05 |
Pauli
You might be able to do this using field functions. I'm thinking something like this:
1) Create a new field function which modifies the field function reporting the boundary face normal velocity. This new field function is a conditional which sets all reverse flow to zero. 2) Use the new field function as the boundary condition. |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
CFX fails to calculate a diffuser pipe flow | shenying0710 | CFX | 7 | March 26, 2013 05:13 |
Volume of Flow Rate (VFR) boundary condition | therockyy | FLOW-3D | 0 | May 23, 2011 15:19 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
How can apply mass flow rate boundary condition? | Sima | Phoenics | 1 | December 1, 2007 19:55 |
