Specifying constant temperature condition to a region
Hi All,
Is it possible to assign a constant temperature condition to a region. Not for the boundary but for a region itself. Region should be maintained at a specified temperature always. Initializing the region would not keep it constantly at a value. For using energy source option, I dont know the volumetric heat generation rate. I heard it is possible in Fluent and it should be possible in Star-CCM+. Please let me know. Thanks, Mahesh |
Yes, it is possible. It is documented in the UserGuide of CCM+. Look for "prescribing constant temperatures in fluid cells" starting from version 5.04.
In the example they use a cell set. This is not necessary if you want the fixed temperature for a complete region. |
Thankyou Olauer, I have already got the answer
Hello Mahesh, i am facing the same issue.
Could you pls explain how you sorted out this issue? |
i Didnt notice
Thanks tisa! |
