residual
Like Tree3Likes
  • 2 Post By flotus1
  • 1 Post By bluebase
Old   September 1, 2013, 01:02
Default residual
akhshik is on a distinguished road
Dear All
Have a nice day
Please find attached file, Results obtained after 715 iteration. As can be seen, the residual curve for some equation is above 1 (about 100). If the residual graph is higher than 1, what can be concluded? Does the model have a problem?
akhshik is offline   Reply With Quote
Old   September 1, 2013, 12:08
Deepak Bansal
Deepak Bansal is on a distinguished road
go to monitor option and go to normalization and instead auto u put as off..after that u check that its less than 1 or not.........if not less than 1 it means problem in ur set up.............
Deepak Bansal is offline   Reply With Quote
Old   September 2, 2013, 03:08
Roman
Roman is on a distinguished road
Actually, I don't think that this looks bad at all. It looks like your values converges well, what you should look out for are sudden "spikes" in your residuals that can push your solution in a divergence state.
Also, taken from manual:
"In general, use normalized residuals to monitor the behavior of the solvers at each iteration to make sure that the solution is converging toward the machine precision. If the simulation is steady state, the convergence is displayed over the total number of iterations. If the solution is time-dependent, make sure that convergence occurs within each time-step."
Roman is offline   Reply With Quote
Old   September 2, 2013, 06:20
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
If this is a transient simulation, decrease the time step size and increase the number of iterations per time step.
akhshik and lcarasik like this.
flotus1 is offline   Reply With Quote
Old   September 7, 2013, 10:40
Smile
Dear all,
thank you for your help
Old   January 29, 2014, 08:46
Default Problem with residuals -- Sudden jump
Aditya
kingmaker is on a distinguished road
Hello all
I have been experiencing similar problem. The thing is .. I have sudden jumps in the residual especially for Tdr ... !
Also Tdr residual(normalization off) starts at 100 and decreases to 0.1 in 10 iterations and then every 40-50 iterations it jumps to 100 again and then starts decreasing for next 40-50 iterations and then again jumps to 100 ... this continues ... !! Rest all residuals are smooth and keep reducing ... in the order of 1e-5 or so .. ! only Tdr is oscillating above 1 or so .. !
I cannot figure out what is going on ... if there is mistake in my problem set up ... it would be very helpful if some one can give me some hints what could be wrong .
Thank you in advance
Aditya
kingmaker is offline   Reply With Quote
Old   February 6, 2014, 19:39
me3840 is on a distinguished road
Typically this occurs with an incorrect near-wall spacing or with incorrect inlet/initial turbulence values.
me3840 is offline   Reply With Quote
Old   March 11, 2014, 12:15
hotash5 is on a distinguished road
you can try to reduce the Under relaxation factor (URF) of turbulence solver to 0.5 or 0.4.
hotash5 is offline   Reply With Quote
Old   May 5, 2018, 02:19
Question
ashokac7's Avatar
Ashok Chaudhari
ashokac7 is on a distinguished road
Send a message via Skype™ to ashokac7
Can someone explain why we need to deactivate normalization for tdr and tke residuals?
ashokac7 is offline   Reply With Quote
Old   May 12, 2018, 17:49
Sebastian Engel
bluebase will become famous soon enough
Hi Ashok,
you don't have to deactivate it. It's just a different way to assess the residuals which might hide problems masked by a normalization, or fabricates false issues.
The normalization just takes the very first iteration's values to normalize all other residuals.
When you already start with a good solution, the first value is already very low, and residuals might won't drop well.
Quantities, such as tke, might have a low residual in the beginning. It then sometimes can happen that such a (relative) residual increases. However, the absolute (without normalization) might still be very low.
ashokac7 likes this.
bluebase is offline   Reply With Quote
Old   May 14, 2018, 01:16
Smile
  #11
ashokac7's Avatar
Ashok Chaudhari
Originally Posted by bluebase View Post
Hi Ashok,
Ok. Got it. Thank you very much Sebastian.
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 13:12
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 08:35
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 06:37
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
