Co-simulation, map values to a non-convective boundary
Old   September 6, 2013, 07:01
Default Co-simulation, map values to a non-convective boundary
Jimmy
Jimmy123 is on a distinguished road
I'm trying to run a co-simulation where I get the heat transfer coefficient and reference temperature from the first fluid flow simulation. In the second simulation, I had planed to use these values for a solid boundary with thermal specification= environment (convection+radiation). But I noticed that the thermal specification changed from environment to convection when I activated co-simulation.
Do you have any suggestion in how I can map the values to a boundary in the second simulation and still use the environment condition there when runing a co-simulation?
Update:
The support told me that it will be possible in the next version, 8.06.002.
But that is too late for me, so I will continue to do it "manually" with two simulations and two macros.
Jimmy123 is offline   Reply With Quote
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Numerical errors in nested domain with pre-calculated boundary values Arnoldinho OpenFOAM Running, Solving & CFD 3 April 4, 2012 10:31
boundary values OFU OpenFOAM Programming & Development 4 August 9, 2011 06:27
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
