Home > Forums > STAR-CCM+
Flow-aligned trimmed mesh of automotive injector's nozzle
Old   September 13, 2013, 04:54
Default Flow-aligned trimmed mesh of automotive injector's nozzle
ecto is on a distinguished road
Hi everybody!
I have a big question: I'd like to construct a flow-aligned trimmed mesh in a nozzle of an injector. I had no problems in doing the same in the holes of the injector.
I tried so many times, but it seems that trim doesn't accept a reference system different from a Cartesian one. I have only one region, and I noticed no advantages in having different regions or using per region meshing. I use also prism layer mesher with many layers at the walls because I do a low y+ calculation.
I attached two images to try to explain. Imagine that these are half sections of the nozzle. The flow of gasoline in the nozzle goes through the hollow space between two overlapping cups.
I use Starccm+ 8.04.
Thanks!
ecto is offline   Reply With Quote
Old   September 13, 2013, 07:32
Jimmy
Jimmy123 is on a distinguished road
I don't think you can get an aligned mesh it like that with a trimmed mesh no matter where you put the alignment location.
Maybe it can get a little better by using more prism layers/advancing mesh. But I think that the best result will be achieved with a directed mesh.
Jimmy123 is offline   Reply With Quote
Old   September 13, 2013, 09:54
Hi Jimmy123! Thanks for the answer!
Oh yes, I just discovered directed meshing, because I come from Starccm+ 7.02.
Do you think I can really obtain a flow oriented mesh, with a lot of prism layers at the wall, with this?
Could you please explain me briefly which are the steps to do in order to mesh with directed meshing?
I think I have to prepare my start surface mesh.
I also read under
Preparing CAD Parts for Directed Meshing
"Each part must have a regular section profile along its length. There cannot be any features intruding into the sweep path between the source and target surfaces. For example, shapes such as Y-junctions cannot be meshed without being split into two mirrored parts."
I don't understand what "regular" does mean...
Old   September 13, 2013, 18:12
Jimmy
I think it can get better by using prisms, but not as good as a directed mesh.
By regular, I think you can think of it as a clean path. It can’t be divided into two channels or so, and there can’t be any shapes that block the way.
I made a small guide and I also attached some images with pasted print screens. I hope it can help you
1. Create a part.
2: Add the part to a region. (so that you later can create the volume mesh)
3: Right click the part, Create mesh operation->Directed mesh
4: Choose a surface to use as source mesh and a corresponding surface to use as target. (Figure 1)
5: Right click on the boundary you choose as source mesh again. This time choose New Source Mesh-> Patch mesh. Then patch the topology. All lines should become green. (Figure 2)
6: After you have done that, change mode to “patch mesh”. Click on the lines and choose how many times they should be divided. All of the lines have to get numbers before you see a mesh. (Figure 3)
7: Close that window, add a New Volume Distribution. Choose how many layers there should be, and then generate the volume mesh (Figure 4)
Old   September 16, 2013, 09:33
Thanks Jimmy!!! That's a great guide! I appreciate it very very much. I'll try to do that.
Thread Tools
Trackbacks are On
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Sonic flow for exhaust nozzle beanlee999 FLUENT 1 May 10, 2012 14:34
Surface aligned mesh rpasiok OpenFOAM Meshing & Mesh Conversion 6 January 7, 2008 06:55
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
Gambit problems Althea FLUENT 21 February 6, 2001 08:05
