October 21, 2013, 23:14 |
Java.net Exceptions
Edit: I have resolved this issue. The cause was my /etc/hosts file not including the name of the machine. After adding the machine name to the hosts file all is well.
I am attempting to run StarCCM+ 8.04.010 on scientific linux 6.4. I can check out a copy from the power on demand server. It seems that once the server tries to start a host on my machine it fails. The final command I see in the output window is: Server::start -host Orion:47827 Orion being the name of my local machine. After several minutes of waiting I get a java error, java.net.UnknownHostException: Orion There are several lines of traceback in this error message, copied in full below. I don't know how to resolve this issue. I've tried reinstalling several times, both double and single precision, and nothing seems to work. I feel like the error is with the JDK and not with StarCCM+ directly, but the java install is packed with the .bin. That said, StarCCM+ seems to think it is using java 1.6 and my console tells me I have java 1.7 installed. Error Message: java.net.UnknownHostException: Orion: Orion at java.net.InetAddress.getLocalHost(InetAddress.java :1374) at org.netbeans.CLIHandler$1.run(CLIHandler.java:568) at org.openide.util.RequestProcessor$Task.run(Request Processor.java:1418) at org.openide.util.RequestProcessor$Processor.run(Re questProcessor.java:1957) Exception with Details [star.base.neo.NeoErrorManager]: error: java.net.UnknownHostException: Orion error: java.net.UnknownHostException: Orion at star.base.neo.NeoClient.connect(NeoClient.java:92) at star.base.neo.ServerConnection.<init>(ServerConnec tion.java:182) at star.base.neo.ServerConnection.<init>(ServerConnec tion.java:160) at star.coremodule.SimulationProcessObject.<init>(Sim ulationProcessObject.java:232) at star.coremodule.SimulationProcessObject.<init>(Sim ulationProcessObject.java:212) at star.coremodule.ui.OpenOptionsDialog$2.run(OpenOpt ionsDialog.java:112) at org.openide.util.RequestProcessor$Task.run(Request Processor.java:1418) at org.openide.util.RequestProcessor$Processor.run(Re questProcessor.java:1957) Caused by: java.net.UnknownHostException: Orion at java.net.PlainSocketImpl.connect(PlainSocketImpl.j ava:195) at java.net.SocksSocketImpl.connect(SocksSocketImpl.j ava:366) at java.net.Socket.connect(Socket.java:529) at java.net.Socket.connect(Socket.java:478) at java.net.Socket.<init>(Socket.java:375) at java.net.Socket.<init>(Socket.java:189) at star.base.neo.NeoClient.connect(NeoClient.java:81) ... 7 more java.net.UnknownHostException: Orion Last edited by Olothreutes; October 21, 2013 at 23:37. Reason: Issue resolved. |
ccm+, java, linux, star |
Floating point exceptions with own modified k-omega SST with Reboud's correction | A_Pete | OpenFOAM Programming & Development | 3 | October 18, 2016 01:45 |
Starccm+ Java.net exception | vsumanth10 | STAR-CCM+ | 3 | April 29, 2010 03:17 |
Error%7eerror triggers crash after handling exceptions thrown by errorexit twice | 7islands | OpenFOAM Bugs | 2 | September 4, 2007 05:24 |
