April 8, 2017, 13:49 |
Mass flow inlet/Velocity flow inlet
SD
Rep Power: 9 |
Hello
I was simulating a simple two pipes joined by 90 degree elbow where a volume flow rate of 15gpm was given. I tried to simulate by letting th inlet flow as mass flow rate but for this case the pressure drop i got from my calculation is way different than the CFD analysis. So I used velocity inlet using the average velocity i calculated analytically. For this one my CFD pressure drop became 103 pa while the analytical one is 150 Pa am just wondering if this difference is okay. Thanks |
April 8, 2017, 14:24 |
Rep Power: 24 |
For pipe flows you should be able to get a lot closer. What are the boundary conditions you are using?
April 8, 2017, 14:27 |
SD
Rep Power: 9 |
April 8, 2017, 14:33 |
Rep Power: 24 |
0.46 m/s is pretty slow, are you sure the flow is turbulent? What does the mesh look like?
April 8, 2017, 14:38 |
SD
Rep Power: 9 |
The fluid type is water with a volumetric rate of 15 gpm so i changed this to mass flow rate which is 0.95 kg/s so i used the basic equation to calculate the velocity v= m/(A*rho) which gives a velocity of 0.468 m/s. I calculated the Re number using R = rho*V*D/dynamic viscosity which gives me about 26683. the diameter of the pipe is around 50.8 mm. I used polyhedral mesh.
April 8, 2017, 15:25 |
Rep Power: 24 |
Okay, the mesh is probably the problem here then. Can you post pictures of it?
April 8, 2017, 17:49 |
SD
Rep Power: 9 |
I was able to figure out the problem. It was my mistake I used a different diameter when I draw the 3d model. Now it seems alright I got 156 pa on the cfd simulation. Which one do you think is the most trusted one with this aspect? The CFD solution or the analytical one?
April 8, 2017, 17:55 |
Rep Power: 24 |
That's not a question I can answer for you. You need to evaluate what assumptions your analytic solution has and how much these impact the real-world compared to the assumptions in your CFD model.
6 Pa doesn't seem to be much to fret over though. |
April 8, 2017, 18:09 |
#9 |
SD
Rep Power: 9 |
Calculate Mass Flowrate and Mass Flow Averaged Total Pressure at inlet and outlet | coolcrasher | OpenFOAM Post-Processing | 7 | November 4, 2021 04:57 |
mass flow inlet and pressure outlet with target mass flow rate | Zigainer | FLUENT | 13 | October 26, 2018 05:58 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
Boudaries for bouynat driven flow with additional mass flux at inlet | Charon | CFX | 2 | April 27, 2013 08:02 |
Mass Flow Inlet | Pravir Kumar Rai | FLUENT | 0 | February 19, 2003 14:03 |
