How to find area of a single mesh element
Old   January 30, 2014, 11:43
Default How to find area of a single mesh element
Dylan
Dyls is on a distinguished road
Hi
I have a temperature field along a x-y plane but I wish to multiply the corresponding temperature of a node with the area that it occupies.
For example, in my derived plane there exists many different sized elements of different shapes (because I am using a polyhedral mesh and cutting through a section). Is there a way to find what each corresponding nodes' areas are and then multiply by it's own temperature?
This would then be calculating a quantity with units of degree multiplied by area.
Thanks so much for your help!
Dylan
Dyls is offline   Reply With Quote
Old   January 31, 2014, 05:07
Ping
ping is on a distinguished road
field function area is available on boundaries but not derived parts like a section plane. so you could place an interface between 2 regions at that location and you will be fine - create a field function $Temperature * mag($$Area) to display or report on.
an approximation might be possible using volume rather than area.
ping is offline   Reply With Quote
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 2 June 24, 2017 05:29
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[ANSYS Meshing] max mesh element size ulalala ANSYS Meshing & Geometry 8 January 20, 2013 17:30
[Other] 2D hex mesh on multi element airfoil Verfblikje OpenFOAM Meshing & Mesh Conversion 0 January 19, 2012 10:55
