January 29, 2014, 21:12 |
Quad-Copter Simulation
Chad
Rep Power: 13 |
I am trying to complete a senior design project building a quadcopter. I am new to CFD, but I have been getting familiar with STAR-CCM+. Can anyone direct me to a tutorial with an analysis similar to that of a model quadcopter?
January 31, 2014, 06:09 |
Ping
Rep Power: 20 |
this is very easy to do with the virtual disk model added in v8.04 - you can combine this with dbfi (6dof), or you could do it using more conventional mrf regions for each rotor and again combining with dfbi, but i am not aware of a tutorial covering all these together - you need to do one each of these special features but they all can be combined
February 1, 2014, 17:04 |
Chad
Rep Power: 13 |
Okay, awesome. So do I actually need the propellers modeled to use the virtual disk model? It seems to me that all I need is the frame of the aircraft, and then I can specify the coordinates and performance characteristics of each propeller using the body force propeller method. Is this correct? Thanks for the help.
February 2, 2014, 00:16 |
Ping
Rep Power: 20 |
the virtual disk blade element method has that advantage that you don't need the geometry and don't mesh the blades, and don't need to run unsteady rigid body motion, so it runs much faster but yields good flow features of the complex flow from a helicopter rotor. but you do need the performance etc details of the rotor
February 3, 2014, 21:42 |
Chad
Rep Power: 13 |
Okay thanks. One more thing: I imported the frame of my multi-rotor copter, and I want to place a blade element model at each of the motor ends. However, I am not sure about the placement of each of these coordinates. Is there any way to find the coordinates of certain points on the model? Also, once I set the origin of each of these virtual disk blade elements on the model, does the program know that the blade elements are attached or part of the model frame?
February 4, 2014, 01:00 |
Rep Power: 24 |
Create a coordinate system for each motor axis. When you make the coordinate system you have the option of choosing points around a circle - use the motor axis. Not sure what you mean by the second question, can you expand?
February 4, 2014, 10:45 |
Ping
Rep Power: 20 |
the virtual disk tools don't actually 'attach' to the rest of your model - they create the flow field and have a range of special reports documented here in the help
Modeling Physics > Modeling Flow and Energy > Specific Flow Phenomena > Virtual Disk Model > Reporting Virtual Disk Results so if you want to also do 6dof motion, i think you will need the force reports from each rotor and apply these as external forces on the free body via the report field functions created when a report is created |
quadcopter copter |
Why my simulation not agree with the wind tunnel experiment | zhaowei | CFX | 4 | July 11, 2015 03:36 |
Solar Radiation in OpenFOAM | plainstyle | OpenFOAM Running, Solving & CFD | 15 | July 8, 2014 04:43 |
Simulation of a complex wing in solidworks flow simulation | niels1900 | FloEFD, FloWorks & FloTHERM | 6 | April 20, 2011 10:44 |
Continuous vs interrupted simulation | sega | OpenFOAM Running, Solving & CFD | 4 | November 3, 2008 14:29 |
strange simulation error | Ralf Schmidt | FLUENT | 2 | May 4, 2007 13:02 |
