January 13, 2014, 20:10 |
Plot temperature along serpentine channel
Sathwik Singari
Rep Power: 13 |
Hello Everyone,
I have attached a figure of my simulation. I am trying to find the temperature at the center along all the 4 channels. I know if I keep drawing a line probes, i can achieve this but it feels tedious. Can anyone suggest me a simpler solution to my problem. Thanks in advance. |
January 31, 2014, 06:27 |
Ping
Rep Power: 20 |
create a arbitrary section along the centre of each channel - this should be a vertical surface. it can be created in 3d-cad or an external cad program. export as an stl file and import as an arbitrary section (in v902 you can use part surfaces directly as arbitrary sections rather than needing to use .stl files)
then if you only want temperatures on a line eg the center of the channel vertically, create a horizontal plane section with the arbitrary section as in the input part - the result is a line and plot or export tempertures on this line part. |
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 09:21 |
CFD post-Fluid mean temperature plot | gtheo | CFX | 14 | March 28, 2016 22:48 |
XY plot, temperature and time | tstensrud | STAR-CCM+ | 5 | April 18, 2015 16:17 |
How to get free stream temperature in boundary condition | saharesobh | FLUENT | 0 | October 9, 2012 17:12 |
Inlet won't apply UDF and has temperature at 0K! | tccruise | Fluent UDF and Scheme Programming | 2 | September 14, 2012 06:08 |
