Importing terrain data for wind flow analysis
Old   March 1, 2014, 16:30
Default Importing terrain data for wind flow analysis
lint is on a distinguished road
Hi, I'm an engineering student assigned a project that would have me use Star to simulate wind flow over various terrain. I'm fairly new to Star.
[EDIT]
I can use matlab to get the data in terms of xyz into a .csv file. I can then import it as a sketch using a 3D polyline. Unfortunately Star doesn't like the sketch and won't extrude from it. I was hoping somebody would be able to help.
Any advice appreciated!
lint is offline   Reply With Quote
Old   March 7, 2014, 08:47
jhv_1729's Avatar
Harshad Joshi
jhv_1729 is on a distinguished road
Try to convert it into a surface from the values you have. That should work.
jhv_1729 is offline   Reply With Quote
Old   March 13, 2014, 15:48
My problem is quite broad. If i had access to solid works i can easily import scanned point cloud data and then save it as a solid object (.step or .x_t) that can then be imported into star.
I can convert these points to a surface in matlab and then export as an .stl but neither Star or solid edge (the CAD i have) accepts these. I've successfully converted this to a step and iges file formats using FreeCad but star still doesn't like them.
I was told that you can somehow separate lines of coordinates so that they are imported as separate curves, which can the be lofted to a surface but i haven't figured how to yet.
Old   March 19, 2014, 15:31
me3840 is on a distinguished road
STAR-CCM+ will import STL files.
me3840 is offline   Reply With Quote
Software availble for CFD analyse a data center air flow Noshan Main CFD Forum 1 November 7, 2013 04:14
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
bellmouth flow analysis munna1981 Main CFD Forum 3 February 14, 2011 13:04
Importing 3D data as CEL into ANSYS CFX 11.0 Dave W. CFX 9 October 19, 2007 09:18
Exp. data for transonic flow J. Held Main CFD Forum 4 April 1, 1999 23:21
