spatial resolution in StarCCM+ for LES
Old   March 10, 2014, 09:37
Default spatial resolution in StarCCM+ for LES
Aqua
aqua is on a distinguished road
Dear All, I am performing LES in StarCCM+. To make sure the mesh is reasonable, I need to check the spatial resolution including Y+, as well as X+ and Z+ in the other two directions. StarCCM+ already has the field function of Y+, but how to get the spacitial resolution for the other direction, X+ and Z+?
Thank you so so much !
Aqua
aqua is offline   Reply With Quote
Old   March 10, 2014, 11:20
me3840 is on a distinguished road
Y+ does not refer to a specific direction, it is a parameter which is relative to the local face normal. X+ and Z+ do not exist.
Please read up here:
http://en.wikipedia.org/wiki/Law_of_the_wall
me3840 is offline   Reply With Quote
Old   March 10, 2014, 12:03
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
x^+ and z^+ do exist.
You can estimate them through the extent of the cell in the respective direction.
Say you have a certain value of y^+ for a cell which has an extent of \Delta y in y-direction.
Then the value for x^+ is
x^+ = y^+ \frac{\Delta x}{\Delta y}.
Same with z^+.
Pay attention that this concept is only valid for the first cell near a wall where y^+ is related to the wall-normal extent of the cell.
flotus1 is offline   Reply With Quote
Old   March 10, 2014, 12:20
I meant they don't exist in STAR-CCM+, sorry.
I don't see any method of calculating these values without user code, unless the geometry is simple enough to know the cell dimensions a priori.
Old   March 11, 2014, 06:52
Aqua
Hi, thank you very much for your reply... which really shocked me... StarCCM+ does not have x+ and z+ ? OMG... If that's true, I would have big trouble with my work..
Thank you.
Aqua
Old   March 11, 2014, 06:57
Aqua
Hello Alex, thank you for your kind reply. I understand your explanation, but my problem is , how to get it from StarCCM+... do you have any idea?
In Starccm+, I can get Y+, but then , to calculate X+ and Z+, I would need the size of the cell (width or length), which is an issue for me...
Thank you
Aqua
Same with z^+.
Old   March 11, 2014, 10:29
flotus1's Avatar
Alex
No need to be shocked, no general purpose commercial CFD software has predefined functions for these values.
As pointed out by me3840, you will need some user code to get them unless you have a very simple setup.
I am no longer working with CCM+, so I cant really give you a hint how to do this.
High resolution image with parafoam Andrea_85 OpenFOAM 5 January 23, 2014 06:39
Mesh Resolution to resolve turbulent boundary layer tongx051 FLUENT 1 October 22, 2013 00:18
importing cad geometry, starCCM 64bit?? syd STAR-CCM+ 3 March 30, 2010 07:17
[Other] Problems with starccm mesh AndTen OpenFOAM Meshing & Mesh Conversion 1 February 23, 2010 04:43
Large difference in grid resolution for diff paper Ben Main CFD Forum 16 April 7, 2007 11:45
