Weird Cl for a car
Like Tree4Likes
  • 1 Post By plucas
  • 1 Post By plucas
  • 1 Post By me3840
  • 1 Post By Michael-STM
Old   March 19, 2014, 15:44
Default Weird Cl for a car
Michele
Michael-STM is on a distinguished road
I'm simulating a classical flow around a car...i have included obviously a moving street and rotating wheels.
The simulation is steady with a k-e model.
I have done the setup for the reports for Cd and Cl.
The Cd is normal...but the Cl of the car is crazy!...the Cl is around 27 watching the details of the report a huge contribution for the Cl is coming from the wheels...what is happening??
Thanks.
Michael-STM is offline   Reply With Quote
Old   March 20, 2014, 08:24
Alex C. is on a distinguished road
It is normal for rotating cylinder to provide a force that is perpendicular to the flow which is a lift.
Here's a wiki on that.
Maybe your results are valid. (Maybe they are not)
You could check the magnitude of the lift force (not lift coefficient) and compare it to gravity force. Rotation of the wheels is not something that can overcome gravity... There should be several order of magnitude of difference.
EDIT : also, remove the rotation from the wheel and run your simulation once. It should be near 0.
Alex C. is offline   Reply With Quote
Old   March 20, 2014, 09:31
me3840 is on a distinguished road
Is your simulation converged? Did you set up the reference values correctly?
me3840 is offline   Reply With Quote
Old   March 21, 2014, 04:28
Default bho
Michele
Taking the Magnus effect into the game the Cl is still non-physical.\
The solution converged and the reference values are the same of the Cd report wich is ok.
I`m feeling like i`m missing something in the setup...i do not know
I have run the sim with some different freestream speed:
Old   March 21, 2014, 04:34
Default Report
Michele
this is the full report:
as you can see the contribution for the weird Cl fully comes from the wheels:
Old   March 21, 2014, 17:28
Can you plot pressure on the surface of the wheels? What does it look like? Do the values make sense?
Old   March 22, 2014, 09:03
plucas's Avatar
Anonymous
plucas is on a distinguished road
What do you have your reference pressure at in setting up the coefficient of lift? Changing this value will drastically change your coefficient value
Michael-STM likes this.
plucas is offline   Reply With Quote
Old   March 22, 2014, 15:13
Michele
I think i`m missing something...this was my idea: the software integrate the shear force and the pressure on the entire model surface it project the vector obtained to a normal vector parallel to the freestream and then it calculate the ratio (F)/(0.5 density v^2 A). Is this correct? in this case the refernce pressure does not influence the result...if this is not true i have setted to 1atm is this wrong?
Anyway...this is the pressure on the wheels...does not look weird?
Old   March 22, 2014, 15:50
plucas's Avatar
Anonymous
You are correct on the equation. I am just speaking of the reference pressure below:
Old   March 22, 2014, 18:54
Those pressures look fine. Are you sure you have the reference values set correctly? I don't think you do. What's the physical value of the lift force?
Old   March 23, 2014, 15:17
Michele
Yeah, you were right. I have set up the reference pressure to 0Pa and now the Cl is back to normality!
plucas likes this.
Old   March 23, 2014, 15:41
plucas's Avatar
Anonymous
Good to hear!
Some questions about making a car racing simulation yossir4 FLUENT 0 November 11, 2013 01:58
Car park ventilation and impulse fans guillaume FLUENT 3 June 27, 2011 11:17
Car park ventilation and impulse fans guillaume Main CFD Forum 12 June 27, 2011 11:16
Car park ventilation and impulse fans guillaume Siemens 0 May 11, 2008 20:00
