Splitting a circle out of a plane rectengular surface
Like Tree1Likes
Old   March 27, 2014, 09:28
Default Splitting a circle out of a plane rectengular surface
hebeldebel is on a distinguished road
I am modifying an old CCM+ simulation which has parts imported from a CAD tool unknown to me.
There is a surface at Geometry->Parts->"Partname"->Surfaces->"Surfacename".
It is a rectangular plane and I would like to split it into 3 surfaces: two circles fully surrounded by the rectangular plane (at a specific location and with a defined diameter).
Is this possible, or do I need to modify the part with a CAD tool?
Thank you for your help.
kind regards,
hebeldebel
hebeldebel is offline   Reply With Quote
Old   March 27, 2014, 09:32
Ping
ping is on a distinguished road
if it is 'real' cad that has been imported you can edit it in 3d-cad and draw the required circles on the surface and then imprint this sketch on to the surface to split it
if not then make some some cylinders in parts and do an imprint mesh operation in parts
ping is offline   Reply With Quote
Old   March 27, 2014, 09:34
thank you very much for your answer, I will try it right away
edit: worked like a charm!
[Gmsh] Hex with transfinite Volume Mjoelnir OpenFOAM Meshing & Mesh Conversion 8 March 30, 2017 08:52
udf to create surface plane (aligned to a surface) Ananthakrishnan Fluent UDF and Scheme Programming 0 May 23, 2013 14:30
Plane stress and plane strain cases for stress analysis Sargam05 OpenFOAM 0 May 3, 2013 18:16
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
solid edge problem....can you help? cindy Main CFD Forum 3 April 5, 2004 13:43
