April 9, 2014, 11:24 |
vacuum cleaner hoses boundaries
Rep Power: 12 |
hello everyone, i'm new to star-CCM+ and to CFD in general.
i'm currently trying to simulate the pressure drop in a vacuum cleaner hoses and don't really succeed. I already import my geometry from CATIA, set up the region with the interface region, inlet and outlet of the hose ans set the physics continuum for solid and gas region I just don't really now what boundary and and phycics value to put in. my capacity is a flow of 120m^3/h (approximately 12m/s), a depression of -35 000 Pa i set the boundary for the inlet and outlet to pressure outlet and one of them with a physics value for pressure at -35 000Pa but the curve for pressure at the inlet stay at 0Pa and the one at the outlet stay at -35 000 Pa. if you can help me i would be really grateful |
April 9, 2014, 12:01 |
Rep Power: 24 |
It sounds like you put in your pressure values and that's what you got out, what's the problem?
I would not use a pressure-pressure BC though. Generally you should use a massflow inlet - pressure outlet condition, it will converge more easily. |
April 10, 2014, 03:18 |
Rep Power: 12 |
thanks for the answer, i will try that but I don't know what physics value to enter in the mass flow inlet (if i put the pressure condition on my outlet and the mass flow value on my inlet it will over constraint my model no?)
April 10, 2014, 12:20 |
Rep Power: 24 |
You listed a volumetric flow rate above, why can't you use that?
April 13, 2014, 12:32 |
#5 | |
Rep Power: 13 |
a) Mass Flow Inlet and Pressure Outlet: Make sure that you convert the volume flow rate into mass flow rate based on density b) Velocity Inlet and Pressure Outlet: I see that you have velocity as well,so you can try using that too and see the results.. |
[ICEM] Can I define periodic boundaries in an unstructured mesh? | Aoki | ANSYS Meshing & Geometry | 11 | September 14, 2018 01:52 |
radiation modeling in vacuum | mirko | OpenFOAM Programming & Development | 7 | May 20, 2016 08:31 |
Assistance in Vacuum pump simulation | enr_venkat | CFX | 5 | November 20, 2012 11:50 |
Setting Flow/Pressure Boundaries in Floworks | Eran | FloEFD, FloWorks & FloTHERM | 3 | August 11, 2009 04:23 |
periodic boundaries - flow through a net | PK | FLUENT | 0 | July 12, 2007 11:58 |
