April 28, 2014, 06:09 |
Reverse flow on outlet face
Oluwaseun Adedeji
I am simulating an axil flow pump. I input a stagnation inlet and a target mass flow outlet but I keep getting a reverse flow on the pump outlet and the pressure rise is also far below the expected value as I have from experimental data.
Does anyone have an idea what I could be doing wrong? Thanks |
[blockMesh] Internal walls of zero thickness | anger | OpenFOAM Meshing & Mesh Conversion | 23 | February 6, 2020 18:25 |
Mass flow inlet and pressure outlet issue | nikhil | FLUENT | 5 | December 11, 2013 12:30 |
Net mass flow inlet vs outlet | Nigui28 | FLUENT | 1 | August 12, 2011 10:09 |
reverse flow in pressure outlet BC | shahzeb irfan | Main CFD Forum | 2 | August 9, 2011 23:40 |
CFDesign V11 -- Reverse flow at outlet | maruthiv | Autodesk Simulation CFD | 1 | June 17, 2011 09:38 |
