Finely dispersed particles in predetermined velocity field |
May 14, 2014, 03:52 |
Rep Power: 12 |
Hi
I am trying to simulate flow problem and use velocity field I get for problem of moving finely dispersed particles in Star-CCM+. I assume particles don't impact velocity field, so I don't need to recalculate it during particles movement modeling. Velocity field modeling needs smaller time step and more calculation time for every iteration. How can I calculate particles movement without recalculating velocity field? |
May 14, 2014, 06:32 |
Ping
Rep Power: 20 |
you mention time step so you have the unsteady solver enabled so if you really do have unsteady flow then the particle motion will also vary with each time step
but if you only want to see the particle motion at a particular time you can leave the lagrangian solver frozen until you are ready then freeze the flow solver and run one iteration of the lagrangian solver since this is all that is required - change back to the steady solver for this and with the flow solver frozen you can run any number of lagrangian runs with different settings to see the effect of particle mass or size etc |
problems after decomposing for running | alessio.nz | OpenFOAM | 7 | March 5, 2021 04:49 |
Particle tracks for already calculated transient velocity field | Tech Neo | Fluent Multiphase | 7 | December 19, 2013 11:20 |
Solving transport equations with known velocity field | Mojtaba.a | OpenFOAM Running, Solving & CFD | 6 | August 6, 2012 07:43 |
Velocity field problem | feizaghaee | CFX | 20 | February 24, 2010 04:23 |
Pressure from velocity field | Svante Hellzén | Main CFD Forum | 5 | November 30, 1999 18:20 |
