May 15, 2014, 05:27 |
Surface Repair on Starccm+
Rep Power: 11 |
Hello everyone,
I am trying to model a flare network on starccm+ (see the geometry on the attached file). I did "Generate surface mesh" and i got the error message on the attached file. It seems that my surface is not closed. So I did a surface repear to identify the problems. I got several problems as face quality, face proximity, non manifold edges and non manifold vertices. The probleme is that I don't know how to fix those mistakes, and I can't generate the volume mesh since I didn't fix this. Thank you very much for your help. Clémence |
May 15, 2014, 06:13 |
vincent
Rep Power: 11 |
hey, i don't know if it will help you but first Focus on free edges in my opinion. To repair click on the number on the Count list and all the problematic part would appear in pink. Then if it's for example problematic faces (that are overcreated) select them one by one or with ctrl or with the Zone selection tool and delete them. Then you will have to fill the holes you created with this Action or the ones made by the Software when importing the geometry. To do so use the hole filling tool. anyway you will see it Comes by doing ( i am not a pro with star ccm+ but this part is easily understandable) you have to Play with edges selection or face selection Tools and with the repairing Tools after you have to try and be Aware that sometimes you will do it wrong but ctrl+z will be usefull. hope it will help you good luck
May 15, 2014, 08:22 |
Rep Power: 11 |
Thank you Vincent for your answer. I try what you tell me to do. I tried to display the face proximity, and the problem is in pink as you said. But this is just a line, and I don't know what to do with this...
May 15, 2014, 08:27 |
vincent
Rep Power: 11 |
okay in selection control can you tick edges instead of faces and click on the Count number again to see what are your repair Options?
May 15, 2014, 08:35 |
vincent
Rep Power: 11 |
I am not sur of what i am going to say but you should really Focus on free edges and non manifold edges repairing and not bother too much with the others. I explain myself i am a newby on star ccm+ so i am still learning but on every Forums and with my coworkers we don't repair face proximity Problems when they are really small like yours and during the Simulation we have no Problem but i assume it depends on what you are doing and i am not qualified to Detail it :-) maybe the user guide or someone else here.
May 15, 2014, 16:04 |
Rep Power: 11 |
Viennent thank you. I did it and it worked really Well actually. Thank you for your answer! It's reAlly easy!
May 26, 2017, 07:19 |
error in star ccm
HARSH KUMAR VERMA
please can anybody tell me how to start learning the star ccm+ can anybody suggest good tutorials.... thanks in advance
May 26, 2017, 10:17 |
Rep Power: 24 |
Look at the user guide, it has dozens of tutorials.
repair surface problem | sieginc. | STAR-CCM+ | 13 | February 25, 2018 19:23 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
repair surface | laura | CFX | 0 | December 29, 2008 05:07 |
Patran Volume Meshing | Deb | CFX | 19 | April 17, 2003 10:56 |
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin | Kaushik | FLUENT | 1 | May 8, 2000 06:47 |
