time step setting
Old   May 26, 2014, 05:27
Default time step setting
Aigerim
Aika is on a distinguished road
Send a message via Skype™ to Aika
Hi all,
Could you answer on my question, I just need to know how to set timestep in Star-CCM+?
I need that my simulation will be done in for ex. 100 timestep, and after I want a finally result, finished result
when i set different tstep results of the same simulation are not the same
Could you explain
thx Aika
Aika is offline   Reply With Quote
Old   May 26, 2014, 05:44
amir2920 is on a distinguished road
You need to check the courant number.
amir2920 is offline   Reply With Quote
Old   May 26, 2014, 05:59
Default pressure drop
Aigerim
thx a lot amir
I have another question, how I can set pressure difference between min 60000Pa and max 101000Pa
when I set like this my results have changed totally
I have an experimental data, velocity = 0.38 mass flux=0.02 kg/sec and pressure difference 60000<pres<101000
after I need to obtain the result, but I have no the same result like experimental data
I simulate a cyclone
thx Aika
Old   May 26, 2014, 06:01
Aigerim
If you have time amir,
could you explain a little bit about my problem on scype or how?
thx Aika
Old   May 28, 2014, 18:50
I think you need to set the inlet boundary conditions and put the pressure outlet for your outlet, and if your mesh and other things would be right, you should be able to obtain the similar pressure drop and experimental values that you have.
Old   May 29, 2014, 05:43
Aigerim
many thanks amir
Time step size and max iterations per time step pUl| FLUENT 33 October 23, 2020 22:50
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 02:20
Sudden jump in Courant number NJG OpenFOAM Running, Solving & CFD 7 May 15, 2014 13:52
Help for the small implementation in turbulence model shipman OpenFOAM Programming & Development 25 March 19, 2014 10:08
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
