June 18, 2014, 08:17 |
Meshing problem
Hello everyone,
I imported a .cas file from fluent to remesh it on starccm+ and work with it. The imported file opens and just contains regions (no geometry parts), a volume mesh that I want to delete and re-do and that's it. The problem comes when I execute the mesher, I set it with values I think are reasonable and when it starts meshing the error "no surface representation marked as starting surface" pops. I don't really know what to do, I traid using the clear generated mesh option, but the error pops anyways. Can somebody tell me what is it that I'm doing wrong? Thank you very much. |
June 18, 2014, 08:40 |
kris
Rep Power: 11 |
Looks like you do not have any surface representations. Check this under the "representations" in the starccm+ tree.
You need to have a surface representation to generate the volume mesh. I think (and I am not sure) the case file in fluent has only a volume representation. You could right click on the "volume mesh" and "extract boundary surface". This will generate a surface representation based on the existing volume mesh. I would not recommend this method as I don't get great surface this way. The best option is to import the surface as a stl or dbs or something. Hope this helps. |
June 18, 2014, 08:58 |
#3 | |
Regards |
Problem with querying the meshing database in CFX-Pre | ashtonJ | CFX | 18 | April 18, 2023 23:49 |
[Other] Hex meshing problem DM12 | patrick | ANSYS Meshing & Geometry | 7 | January 9, 2015 07:21 |
[ANSYS Meshing] Inflation - Airfoil Meshing - Divergence problem | dalecooper | ANSYS Meshing & Geometry | 0 | July 19, 2013 07:04 |
Meshing problem in GAMBIT | Vidya Raja | FLUENT | 0 | May 20, 2006 23:31 |
GAMBIT meshing problem | Gauthier Lambert | Main CFD Forum | 1 | August 3, 2000 09:22 |
