June 23, 2014, 07:21 |
Monitoring Inner Iterations
Henry Arrigo
Rep Power: 15 |
Hi all,
I am conducting an unsteady simulation which includes aerodynamic characteristics of a rotating airfoil. Since the location of the airfoil is variable, I wan to get sure if the force coefficients are converged in each time step. Is it possible to plot these reports in a way that I would be able to see the convergency of Cl & Cd in each time step? Thanks |
June 23, 2014, 16:01 |
Rep Power: 24 |
Yes, you can make report plots a function of iteration.
You can also force your timesteps to keep iterating until convergence for these reports is reached. |
June 24, 2014, 04:06 |
Henry Arrigo
Rep Power: 15 |
Thanks,
Where can I do this? What should I do in order to have such a plot? |
June 25, 2014, 06:21 |
Rep Power: 24 |
Just click on the plot and look at the properties. You have to do the same for your monitors as well.
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
