July 21, 2014, 08:06 |
vof problem
David
Rep Power: 14 |
Dear all
I am facing a problem about VOF. My structure is a hollow cylinder put in a wave filed. when the wave comes, water inside the hollow cylinder will rise and fall. When I look into to the scalar scene there's something wrong with the volume fraction of water within the hollow cylinder as shown in the attachment. It will be appreciated if some can help me to explain what may cause such kind of problem. |
July 21, 2014, 09:00 |
Arun Krishnan.L.H
Rep Power: 13 |
Hey Dai,
Where are you? Not on Skype anymore? What motion are you using for the cylinder? Arun |
July 21, 2014, 20:31 |
Rep Power: 24 |
It just looks like a lot of air is inside the cylinder. Are you sure the sim is converging mass each timestep? What is your CFL number for the interface?
July 22, 2014, 13:26 |
David
Rep Power: 14 |
Hi me3840
Thank you for your answer. Well, when talking about CFL, the CFL for the interface is larger than 1 which is not good. So I am currently testing a case with smaller time step size. I have one question, basically, we should keep the CFL number below 0.5 to use second order temporal discretization method, however, mesh around the device is so small that if the CFL is kept below 0.5 the computation time will be sky high. Can you give some suggestion about this issue? Thanks in advance. |
July 22, 2014, 19:40 |
Rep Power: 24 |
Eh, you may be able to skate by with 2 or higher. Just measure the mass conservation of the heavy phase and make sure you're not loosing too much of it.
Display Modes | |
Interesting problem: Parallel Processor VOF Fluent + Dynamic Mesh + System Coupling | spaceprop | FLUENT | 5 | September 2, 2014 10:43 |
a problem of incompressible two phases(water and gas) with VOF Method | zhangweisnoopy | Main CFD Forum | 9 | August 12, 2011 09:25 |
Two-phase VOF problem | scott copland | FLUENT | 3 | March 15, 2007 08:25 |
A Problem with setting the time step in VOF model | Le | FLUENT | 2 | July 20, 2006 23:00 |
problem with VOF. | Marc | FLUENT | 1 | June 5, 2002 09:17 |
