August 14, 2014, 10:13 |
Cannot mesh imported .igs file
Justin
Rep Power: 11 |
I have been importing a .igs file as a new region. The part is made up of around 800 separate bodies so I don't bother importing it as a new part. I build a wind tunnel around it in the 3D CAD Modeling.
Before I generate a volume mesh, I display the mesh and the part seems to already have a mesh on it. When I generate a volume mesh (surface remesher and polyhedral) the output says that no cell/vertices/faces were created on the part but rather only in the wind tunnel. How do I mesh this part?! Does it have to be a surface wrapper? Edit: Found this tutorial on surface meshing and it is great! https://www.youtube.com/watch?v=OGIYYLziZWI Last edited by jpesich; August 14, 2014 at 12:20. |
August 20, 2014, 08:43 |
Gajendra Gulgulia
Rep Power: 12 |
Hello Justin
When importing a file in neutral format, CCM+ tesslates the geometry by itself. This is very coarse and rather a bad mesh which CCM+ cannot volume mesh. You need to create mesh models and remesh the surface appropriately. If you are using one mesh continua for multiple regions make sure that you enable "per region meshing" I would suggest you to avoid wrapper to as much extent as possible. |
August 21, 2014, 11:50 |
Ping
Rep Power: 20 |
it is silly to import directly into regions with the modern versions of star-ccm+ especially with that many parts
you should import into parts and unless you have extremely good quality cad with that number of parts you probably do need to wrap to get a closed surface for the internal shape and that is another reason to use parts based meshing since wrapping is much better up there then make a region out of the wrapped surface and the wind tunnel part then create an automatic mesh operation to surface mesh and volume mesh do the racing car tutorial in the meshing section |
Display Modes | |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 12:32 |
2.0.x on Mac OSX | niklas | OpenFOAM Installation | 74 | March 28, 2012 17:46 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 12:44 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
