August 24, 2014, 03:03 |
Appropriate time step
Henry Arrigo
Rep Power: 15 |
Hi all,
How is it possible to calculate overall mean value of convective Courant number with a given time step. I want to set the overall mean value of convective courant number around 1, but I don t know how to choose the appropriate time step. Thanks |
August 24, 2014, 09:45 |
Ping
Rep Power: 20 |
create report ot type mean for cfl then use this in a field function formula calculate the required timestep and use this as the timestep
however this is maybe not a good idea depending on your flow since an important area of the flow might have cfl much higher than one and so is being poorly modelled |
August 25, 2014, 05:44 |
Henry Arrigo
Rep Power: 15 |
thanks ping,
would you give me an example of what you name "an important are"? and, based on what you said it must be more rational to use maximum CFL report instead of the average, rights? |
August 25, 2014, 06:59 |
Ping
Rep Power: 20 |
an important area is somewhere where capturing the flow accurately is important ie there are areas in most cases where it is less important to have a fine mesh or a reasonable cfl number
yes based on max cfl is much safer but could be too conservative if some spurous cells have large values for a silly reason |
September 4, 2017, 17:54 |
#5 | |
Can
Rep Power: 8 |
I created a report of Volume average and select convective courant number as a scalar function. Is this correct or should i create a report of surface average? Then how can i obtain deltax to calculate my suitable time step? Regards |
Display Modes | |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 14:40 |
Rapidly decreasing deltaT for interDyMFoam | chrisb2244 | OpenFOAM Running, Solving & CFD | 3 | July 1, 2014 17:40 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 07:37 |
Full pipe 3D using icoFoam | cyberbrain | OpenFOAM | 4 | March 16, 2011 10:20 |
calculation diverge after continue to run | zhajingjing | OpenFOAM | 0 | April 28, 2010 05:35 |
