September 20, 2014, 09:08 |
Mesh will not refine
Rep Power: 11 |
Hi all,
As the title says I'm having an issue refining a mesh further. The picture attached shows my wind turbine that I am simulating, and as you can see the mesh downwind of the blades get progressively courser as you go further back. The problem is I used the same settings in all three of the custom controllers that control this, ie the hub, blades and tower. Is there some thing I'm not aware of that could be stopping me from getting the same mesh throughout the whole turbine? I have the correct parts selected in each custom control. |
September 23, 2014, 22:35 |
Rep Power: 24 |
If you're going to use a volume control on the polymesher you should probably drop the volume blending factor. It's in the default controls. Use something around 0.1 or 0.2 and keep changing it until you get good growth.
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
[ANSYS Meshing] How to refine a diffuser mesh in axial and circumferential directions seperately ? | ulvi90 | ANSYS Meshing & Geometry | 0 | December 10, 2013 08:19 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
