March 22, 2015, 11:53 |
Starccm+ yaw test function
Harshal
Rep Power: 11 |
Hello
I am trying to perform a yaw test on ship so i created the yaw test function to use in the Motion 'Rotation and translation'. But when i create a vector function and put that in rotation rate in 'Rotaion and translation' i get error "Function does not evaluate to a scalar: Simulation>MotionManager>RotatingAndTranslatingMot ion("Rotation and Translation")>ScalarPhysicalQuantity>InlineFieldFu nction("InlineFieldFunction")" it does work wen i define function as scalar. can any one explain me the reason ? as as angular vel. is vector it should work with vector function. Thnx |
March 22, 2015, 14:45 |
Tim Meier
Rep Power: 11 |
The rotation rate is a scalar value, so a vector function doesnīt make sense. Thatīs the reason why the function, defined as scalar, is working.
The angular velocity (units 1/s) describes the rotation rate around an origin (and the direction of rotation, meaning clockwise or counter clockwise). It is a pseudovector quantity. So what you are looking for, is maybe a coordinate system that is moving to describe the changing rotation position. |
March 23, 2015, 23:54 |
Matt
Rep Power: 17 |
True, the input is a scalar, but velocity is always defined as a vector. There should be an input for a vector that defines a rotational axis and then a scalar to define magnitude. I think you are just over complicating the issue.
Display Modes | |
compressible flow in turbocharger | riesotto | OpenFOAM | 50 | May 26, 2014 02:47 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 06:42 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 07:51 |
Droplet Evaporation | Christian | Main CFD Forum | 2 | February 27, 2007 07:27 |
