wall porosity for degassing boundary condition |
March 24, 2015, 23:25 |
Sangwoo Kim
Rep Power: 11 |
Hi all.
I want to specify degassing boundary which acts as a wall for water, and as a outlet for air, so only air can leave through it. But I'm using VOF model, not dispersed model, so I cannot use permeable wall. I should use wall porosity. In this case, how should I specify relevant models? I added wall porosity model in water phase, and specified numbers as follows. porous inertial resistance = 1000000 porous viscous resistance = 100000 But scalar scene of velocity seems that air does not go through the wall. Did I do incorrectly? Any comment will be appreciated. Thank you.
Best regards |
March 24, 2015, 23:30 |
Sangwoo Kim
Rep Power: 11 |
I think wall porosity model should be added to the air phase, not the water phase.
If it is, then how can I decide the values? Thank you.
Best regards |
March 25, 2015, 15:55 |
Matt
Rep Power: 17 |
I could be wrong, but I thought the porosity setting was only used for heat transfer. (setting % of solid vs fluid).
March 25, 2015, 20:18 |
#4 | |
Sangwoo Kim
Rep Power: 11 |
Thank you.
Best regards |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
isothermal wall boundary condition | Neil | Main CFD Forum | 3 | November 9, 2015 02:34 |
pressure boundary condition for a rotating wall | barteljoris | CFX | 6 | March 16, 2015 17:21 |
Dirichlet boundary condition for additional variable on the wall | ftab | CFX | 13 | January 27, 2013 12:24 |
