Home > Forums > STAR-CCM+
Turbulent viscosity limited
Old   May 5, 2015, 14:48
Default Turbulent viscosity limited
MissCFD is on a distinguished road
When I start my simulation, I have already turbulent viscosity limited at the first iteration what does that mean ? My simulation is initialized with constant variables and it seems to be a problem ... I have to initialize with an other simulation in order to my simulation works. Can somebody please explain it to me ?
Thank you
MissCFD is offline   Reply With Quote
Old   May 5, 2015, 16:58
Matt
MBdonCFD is on a distinguished road
Check your boundary conditions. 9 times out of 10 that is the problem on something like this.
It could also be your initialization. How did you initialize your solution?
MBdonCFD is offline   Reply With Quote
Old   May 5, 2015, 17:49
Matt
Sorry, I guess I didn't read carefully. It definitely sounds like you need to initialize differently. Try using Expert Initialization (Grid Sequencing) under Solvers. Basically this simplifies the governing equations and solves your flow over a series of ever finer meshes (using the previous course mesh results as your initial conditions). Finally interpolating the last of the grid sequencing results onto your actual mesh.
This can be an issue with very complex flows, rotating flows, etc... However, it should solve your problem and also cut down on your run time. I have saved litterally days on some rather beefy analysis using this option.
Old   May 5, 2015, 20:25
Thank you very much for your response but I have already tested ''Expert Initialization'' and it doesn't work either, it give me outliers with very high-values' for velocity ...
Do you think that if I reduce initial conditions for turbulence intensity and turbulente length scale, it can work ? Because I took the same values that I put for my boundaries ...
Thread Tools
Trackbacks are On
RSM+2nd ordedr causes turbulent viscosity limited to viscosity ratio of.... khsiavash Main CFD Forum 10 January 7, 2016 13:30
Atmospheric Boundary Layer Limited Turbulent Viscosity lint STAR-CCM+ 4 April 15, 2014 13:12
Turbulent viscosity ratio limited to 1.10^5 in boundary layer ingestion loicflouriot FLUENT 0 May 27, 2012 07:31
Turbulent Viscosity ration limited in Sliding Mesh rotation sreenivas STAR-CCM+ 1 March 29, 2012 08:45
turbulent viscosity limited to ...??? alexandre FLUENT 2 February 22, 2006 00:22
