May 28, 2015, 09:14 |
Mesh of Square Cylinder
Rep Power: 10 |
Hello everyone!
I am dealing with vortex shedding effects in a transonic flow regime around a square cylinder. For a start my study shall remain in 2D. In order to discretise the domain, I applied the Directed Mesher (PBM). I understand that the same meshing approach has been applied to these kind of geometries before, so I didn't expect any issues in that regard. However, once I started the simulation and observed the velocity field, it'd become apparent that the mesh has a big influence on the simulation result. It seems that regions with small cell size somehow act as a boundary, which yields unphysical results. I have attached some Screenshots of the mesh and one of the velocity field, where the mesh influence is clearly visible. Does anyone have a clue why this problem could occur?Any help or hint is greatly appreciated Capture du 2015-05-28 15:03:30.png Capture du 2015-05-28 15:02:49.png Capture du 2015-05-28 15:13:15.jpg |
May 28, 2015, 11:55 |
Alex
Rep Power: 46 |
Looks like a classic example for a solution that is not converged.
If you are using an implicit solver, run more iterations / iterations per time step. A better meshing approach would be an o-grid around the block. This way you could avoid small / high aspect ratio cells in the free stream region that cause the poor convergence behavior |
[blockMesh] 3-D Mesh in a cylinder | Nikunj.R | OpenFOAM Meshing & Mesh Conversion | 32 | July 9, 2023 13:22 |
[Gmsh] GMSH: Structured mesh of a square inside a circle | wc3speler | OpenFOAM Meshing & Mesh Conversion | 3 | September 18, 2019 16:13 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[blockMesh] mesh generation inside/around 3D cylinder | Cloudy1988 | OpenFOAM Meshing & Mesh Conversion | 10 | August 23, 2012 14:13 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
