Machine configuration for multiphase flow
Old   July 15, 2015, 13:58
Default Machine configuration for multiphase flow
Kamal Bisht
Bisht is on a distinguished road
I have a student version of Star-ccm+ for my thesis work in a company but with it I can use only 6 cores.
My task is to simulate Multiphase flow (Fuel tank refueling) with around 3.5M cells, time step is e-5 for the total physical time of around 2s.
My computer configuration is like i7, 32 gb Ram, 2.85 ghz processor and 8 cores(though can use only 6)
Is this configuration enough for my simulation?
Someone told me that it will take 2 weeks for this kind of simulation which is too much considering the thesis period.
The company has the industry license for the Star-ccm+ but at the moment all are occupied so they arranged student license for me
Bisht is offline   Reply With Quote
Old   July 15, 2015, 20:35
Michael Prinkey
mprinkey will become famous soon enough
There are too many physical and code-specific variables to answer your question without knowing a lot more information. If you have the simulation set up, run it for 100 timesteps (to get startup overhead out of the way) and then time the next 100. The second 100-step measure should give you rough idea of sec/timestep and you can try to extrapolate from there. Multiphase problems can be particularly devilish to converge sometimes due to real physical behavior (bubbles bursting, etc.) so that may make your extrapolation a bit understated, but it should give you a hint if it is going to take a day, a week, or a month.
mprinkey is offline   Reply With Quote
mass flow inlet and pressure outlet with target mass flow rate Zigainer FLUENT 13 October 26, 2018 05:58
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 07:40
Configuration for Client Machine in Linux Raymond CFX 0 July 22, 2004 03:50
