July 15, 2015, 13:58 |
Machine configuration for multiphase flow
Kamal Bisht
Rep Power: 10 |
I have a student version of Star-ccm+ for my thesis work in a company but with it I can use only 6 cores.
My task is to simulate Multiphase flow (Fuel tank refueling) with around 3.5M cells, time step is e-5 for the total physical time of around 2s. My computer configuration is like i7, 32 gb Ram, 2.85 ghz processor and 8 cores(though can use only 6) Is this configuration enough for my simulation? Someone told me that it will take 2 weeks for this kind of simulation which is too much considering the thesis period. The company has the industry license for the Star-ccm+ but at the moment all are occupied so they arranged student license for me |
July 15, 2015, 20:35 |
Michael Prinkey
Rep Power: 25 |
There are too many physical and code-specific variables to answer your question without knowing a lot more information. If you have the simulation set up, run it for 100 timesteps (to get startup overhead out of the way) and then time the next 100. The second 100-step measure should give you rough idea of sec/timestep and you can try to extrapolate from there. Multiphase problems can be particularly devilish to converge sometimes due to real physical behavior (bubbles bursting, etc.) so that may make your extrapolation a bit understated, but it should give you a hint if it is going to take a day, a week, or a month.
mass flow inlet and pressure outlet with target mass flow rate | Zigainer | FLUENT | 13 | October 26, 2018 05:58 |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
potential flow vs. Euler flow | curious ... | Main CFD Forum | 23 | July 21, 2006 07:40 |
Configuration for Client Machine in Linux | Raymond | CFX | 0 | July 22, 2004 03:50 |
