August 31, 2015, 16:41 |
Fan Diffuser
Anon
Rep Power: 10 |
Has anybody simulated an outlet diffuser on an axial fan. I am running some moving reference frame simulations with a mixing plane and without the diffuser I am seeing mass flow rates in line with the expected data sheet values. However I am seeing no increase in flow rate when I add the diffuser. Increase should be around 13%. I have tried some standard solution, increase inlet and outlet plenum size, refine the mesh. Has anybody dealt with this problem specifically before.
Thanks, John |
September 1, 2015, 12:04 |
Matt
Rep Power: 17 |
This is most likely a result of your model/setup. Can you share some pictures of your domain/model to get a feel for what you are actually trying to analyze?
How to build current blower fan model in Flotherm | eric0722 | FloEFD, FloWorks & FloTHERM | 3 | January 2, 2021 02:36 |
Fan flow simulation in open air | idiroft | CFX | 5 | June 10, 2014 07:34 |
Simulation of Axial Fan Flow using A Momentum Source Subdomain | Liam | CFX | 28 | July 16, 2013 08:24 |
fan driven flow, Fan BC validation (getting lost) | soonic | OpenFOAM Running, Solving & CFD | 0 | July 7, 2013 19:16 |
Considering the operating point instead of the fan curve | saisanthoshm88 | CFX | 8 | August 9, 2012 06:57 |
