September 11, 2015, 06:17 |
The Size of CV
Sidharth
Rep Power: 10 |
Hello Everyone,
I wanted to know the procedure for determining the size of control volume, for a vehicle on which the under hood thermal analysis is done. Only the air flow has to be simulated. The thermal boundary conditions are given. Thanking You, Sidharth. Last edited by sidharth9426; September 11, 2015 at 12:43. |
September 13, 2015, 20:11 |
Rep Power: 24 |
The CV needs to be large enough such that the relevant physics are captured. For underhood cases this means the aero solution plays a key role and the CV must be relatively large.
September 13, 2015, 23:22 |
Sidharth
Rep Power: 10 |
Actually I wanted to know the how to decide the dimension of CV, I mean is there any thumb rule relation which are like, length of CV= X * length of the vehicle... And similarly for top and side length of CV.. |
September 14, 2015, 19:58 |
Rep Power: 24 |
The rule of thumb depends on the physics. I mean, generally for aero simulations you will want 10 lengths downstream, 5 upstream, maybe 5 on the sides, but this will depend on the type of vehicle and also doesn't take into account that you're not doing an aero simulation.
September 14, 2015, 22:32 |
Sidharth
Rep Power: 10 |
Yes, I am not doing any aero simulation. I am modelling air and the variation in temperature under the hood of the car.
I saw many technical papers, but the process of deciding size of CV was mentioned in none. So if you can give some reference, it will be great help.. . |
[snappyHexMesh] crash sHM | H25E | OpenFOAM Meshing & Mesh Conversion | 11 | November 10, 2014 11:27 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
