Modeling floating plate with a regular wave |
October 10, 2015, 12:21 |
Mehdi
Rep Power: 10 |
Hi
I'm currently doing a simulation of a large plate floating on sea,and i want to calculate the vertical displacement of plate in a regular wave,for this,i use Star ccm+ coupling with Abaqus co-simulation,it works but the answers are False,for example for a 0.5 m wave height ,and 100 m wave length ,the result of vertical displacement in abaqus shows over than 15 m. and these are my inputs : rectangular plate properties : 2*300*60 m Enabled Models Three-Dimensional (Selected automatically) Gradients (Selected automatically) Time Implicit Unsteady Material Eulerian Multiphase Multiphase Model Volume of Fluid (VOF) Viscous Regime Turbulent Reynolds-Averaged Turbulence K-Epsilon Turbulence Optional Models Gravity VOF Waves if someone can help me,please contact with this email: booymeister@gmail.com |
October 12, 2015, 09:20 |
Rep Power: 24 |
Is the plate deforming? Why are you using abaqus?
Are you sure the size of the model is correct? Check that the plate is sized correctly, your answer seems very large considering the inputs. |
October 12, 2015, 09:38 |
Roman
Rep Power: 15 |
Sounds like your coupling frequency is to low. What timestep do you have in starccm and what is your coupling timestep set to?
October 12, 2015, 09:44 |
#4 | |
Mehdi
Rep Power: 10 |
Yes,deformed,and i need the deformed shape of plate, using abaqus for better analysis,to reach the displacement of amplitude. |
October 12, 2015, 09:45 |
Mehdi
Rep Power: 10 |
October 12, 2015, 09:47 |
Roman
Rep Power: 15 |
This is also true for the maximum allowable time step in abaqus setup as well?
October 12, 2015, 09:49 |
Rep Power: 24 |
0.01s is probably far too large for the fluid simulation. Does each timestep converge? The position and deformation as well as the fluid parameters (drag, left, etc) should converge every timestep.
October 12, 2015, 10:58 |
Mehdi
Rep Power: 10 |
thanks dear friends,
when i simulate wave, i see the several wave under whole plate,if i want to model one incident wave moving from the first point to the end point of my plate,what can i do? |
October 12, 2015, 11:05 |
#9 |
Roman
Rep Power: 15 |
I would define a first order VOF wave and set "point of water level" x value to the start position of the plate. When the simulation runs the wave will have a defined velocity at which it propogates to the end point.
October 13, 2015, 09:26 |
#10 |
Mehdi
Rep Power: 10 |
Thnks dear , u said my step time is large,what is the better step time do u think ? For both abaqus and star ccm ?
October 13, 2015, 09:32 |
#11 |
Mehdi
Rep Power: 10 |
If i want to change the step time,what is your idea about both abaqus and star timestep? As you know my model has a large dimentions..
October 13, 2015, 17:54 |
#12 |
Rep Power: 24 |
Well you want to ensure that the CFL on the interface of the water and air is no greater than 1. You may have to drop the timestep to make that happen. I would suggest starting at 3ms or so.
October 21, 2015, 12:26 |
#13 |
Mehdi
Rep Power: 10 |
thanks for ur great help,i have a new problem now,which kind of mesh do you use for this dimensions of fluid domain,and what is the maximum cell size that i can use?
October 22, 2015, 00:33 |
#14 |
Rep Power: 24 |
I can't answer what size to use. You must use engineering judgement to choose a mesh size that resolves important gradients while maintaining acceptable accuracy and speed.
As far as what kind of mesh to use, wave calculations like this mean you really only care about 2 of 3 dimensions, so a trim grid with anisotropy near the domain boundaries and more isotropy in the region of interest is usually more efficient. |
Pressure for wave height in an Water Wave Tank | Cluain | CFX | 8 | December 6, 2021 03:58 |
IHFOAM - Wave generation with moving boundaries | Phicau | OpenFOAM Verification & Validation | 0 | May 18, 2015 04:53 |
Which code to go for free surface wave modeling.. | Ted Chu | Main CFD Forum | 7 | December 29, 2008 15:42 |
Water Wave modeling????? | rawin | FLUENT | 2 | October 1, 2005 10:43 |
Modeling Wave Sections | J. C. Patrick | Main CFD Forum | 7 | January 22, 2000 13:27 |
