How to adjust the Scalar Legend on several Scenes? |
February 16, 2016, 03:14 |
Rep Power: 10 |
Hey guys!
I have to compare several velocity Scenes and dont know how to adjust the Colors of the scalar legend on each Scene. As seen in the screenshot below the Colors arent comparable. I saw the "Auto Range Mode" on the scalar field Options (Change from "Displayer Parts" to "All Regions"). Is this the only Option? Thank you in advance! -edit- Ok, just saw that you can adjust the min/max values manually. Isnt that fitting on my purpose, but a fast solution. Of course I would be happy about other hints |
February 16, 2016, 13:48 |
Rep Power: 10 |
Adapting the min/max values to the same one in all scalar displayers is the only solution. Otherwise "Auto Range" will adapt it to the actual values in each displayer which naturally can differ.
Don't forget to deactivate clipping in the displayers as well. Otherwise the cells with values below min and above max will be blank by default. |
February 17, 2016, 03:00 |
#3 | |
Rep Power: 10 |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
Issue symmetryPlane 2.5d extruded airfoil simulation | 281419 | OpenFOAM Running, Solving & CFD | 5 | November 28, 2015 13:09 |
Diverging solution in transonicMRFDyMFoam | tsalter | OpenFOAM Running, Solving & CFD | 30 | July 7, 2014 06:20 |
compressible flow in turbocharger | riesotto | OpenFOAM | 50 | May 26, 2014 01:47 |
